[GRASS-dev] 6.4 Nviz Windows problems
Glynn Clements
glynn at gclements.plus.com
Sun Dec 21 22:44:46 EST 2008
Paul Kelly wrote:
> I had a problem compiling nviz from the 6.4 release branch on Windows,
> with unrecognised Tcl/Tk symbols. Reverting r32244 to put the Tcl/Tk
> library flags in among the other library linking flags seems to fix it:
> http://trac.osgeo.org/grass/changeset/32244
> I haven't committed as I don't understand the reason for that change.
$(XTRA_LDFLAGS) definitely should go after $(ARCH_OBJS) and
$(SURFLIB). Otherwise, it won't work if either the Tcl/Tk or OpenGL
libraries are static libraries.
> Trying to run nviz brings up a further error - see attached -
> unfortunately no time to look into it further now.
I can't reproduce this. Does the file appear to be valid?
