[GRASS-dev] Re: [GRASS GIS] #399: Added "backlink" functionality to r.walk, r.cost & r.drain
Michael Barton michael.barton at asu.edu
Sun Dec 21 22:25:53 EST 2008
On Dec 21, 2008, at 7:16 PM, <grass-dev-request at lists.osgeo.org> wrote:
> Date: Mon, 22 Dec 2008 01:48:38 -0000
> From: "GRASS GIS" <trac at osgeo.org>
> Subject: [GRASS-dev] Re: [GRASS GIS] #399: Added "backlink"
> To: undisclosed-recipients:;
> Message-ID: <051.c307af75837cf7c8e39fc03955670860 at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
>  Reporter:  cnielsen     |       Owner:  grass-dev at lists.osgeo.org
>      Type:  enhancement  |      Status:  new
>  Priority:  major        |   Milestone:  6.4.0
> Component:  Raster       |     Version:  unspecified
> Resolution:               |    Keywords:
>  Platform:  All          |         Cpu:  All
> Comment (by dylan):
> r.cost.patch applies and compiles against GRASS64-SVN r34983
> r.drain patch: error on applying to documentation, does not compile
> (Stripping trailing CRs from patch.)
> patching file main.c
> patching file description.html
> Hunk #4 FAILED at 208.
> 1 out of 4 hunks FAILED -- saving rejects to file description.html.rej
> main.c: In function â:
> main.c:697: error: â undeclared (first use in this function)
> main.c:697: error: (Each undeclared identifier is reported only once
> main.c:697: error: for each function it appears in.)
> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error
> r.walk.patch: applies with one error, and compiles
> Hunk #4 FAILED at 149.
> patching file stash.h
Same results on Mac OS X (reported offline).
Michael
