[GRASS-dev] Re: [GRASS GIS] #399: Added "backlink" functionality to r.walk, r.cost & r.drain
GRASS GIS trac at osgeo.org
Sun Dec 21 23:14:44 EST 2008
  Reporter:  cnielsen     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  Raster       |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  All          |         Cpu:  All
Comment (by dylan):
 One more set of comments:
 1. The patched r.walk appears to have the same problem as patched r.cost--
 Seg fault if the outdir option is not specified.
 2. Output direction from patched r.walk is not accepted by patched
 'r.drain -d'.
 I have been using data on this page
 (http://casoilresource.lawr.ucdavis.edu/drupal/node/544) as my test cases.
 The elevation surface and start/stop points are included at the bottom of
 the linked page.
 Cheers,
 Dylan
Ticket URL: <http://trac.osgeo.org/grass/ticket/399#comment:7>
