[GRASS-dev] mac error in GRASS 7 compiling
Tue Dec 23 01:57:43 EST 2008
William Kyngesburye wrote:
> > I suggest replacing the top-level macosxapp rule with the following:
> > NIBSRC := $(wildcard English.lproj/MainMenu.nib/*)
> > NIBDST := $(patsubst English.lproj/%,$(APPDIR)/English.lproj/%,$
> > (NIBSRC))
> Oh, and should MOD_OBJS be just main.o now? ... or, no, FILES -> MacOS/
> GRASS -> main.o, so no MOD_OBJS?
There's no need, as you have your own linking rule for
$(APPDIR)/MacOS/GRASS.
MOD_OBJS is used to generate ARCH_OBJS, which is the list of
prerequisites for the standard targets defined in Module.make,
Etc.make, Lib.make and DB.make.
As you aren't generating one of those targets, it won't be used.
