[GRASS-dev] Re: [GRASS GIS] #411: Makefile uses LD instead of GCC for linking leads to undefined symbol: __stack_chk_fail_local
GRASS GIS trac at osgeo.org
Tue Dec 23 10:17:32 EST 2008
  Reporter:  RRosario             |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect               |      Status:  new
  Priority:  major                |   Milestone:  6.4.0
 Component:  SWIG (all bindings)  |     Version:  svn-develbranch6
Resolution:                       |    Keywords:  undefined symbol __stack_chk_fail_local
  Platform:  Linux                |         Cpu:  x86-32
Comment (by kyngchaos):
 This isn't right on OSX either.  We've spent some effort to get the
 wxpython nviz and vdigit to compile correctly on different platforms, so
 maybe that method should be used here also (patch attached).
 There is still cleanup needed to completely conform to the GRASS make
 system, but it should compile correctly now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/411#comment:2>
