[GRASS-dev] Re: [GRASS GIS] #412: add bbox check to d.rast
trac at osgeo.org
Thu Dec 25 14:40:54 EST 2008
Reporter: karme | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: trivial | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: Unspecified
Comment (by glynn):
Replying to [ticket:412 karme]:
There appear to be a couple of things wrong here:
1. It assumes -o (or the lack of -n in 7.0). Without -o or with -n, a
raster which doesn't overlap the current region should result in a solid
rectangle in the map's null value colour.
2. D_cell_draw_setup() is called unconditionally, but D_cell_draw_end() is
only called if the raster is visible. These calls must be matched, i.e.
either both must be called, or neither.
Apart from that, I would suggest making the patch against 7.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/412#comment:2>
