[GRASS-dev] Re: [GRASS GIS] #377: gis.m/Map Display fails to handle
vector layers with multiple databse layers
trac at osgeo.org
Fri Dec 26 03:17:16 EST 2008
#377: gis.m/Map Display fails to handle vector layers with multiple databse
layers
Reporter: ploewe | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: gis.m database query
Platform: All | Cpu: OSX/Intel
Changes (by cmbarton):
* platform: Linux => All
* version: 6.3.0 => svn-develbranch6
* component: Tcl => Vector
* cpu: x86-32 => OSX/Intel
Comment:
This appears to be a bug in d.vect, not in the TclTk gui. I just tried
this out in the GRASS 6.4 development version from the SVN.
From the command line in an xmon...
GRASS 6.4.svn (Spearfish60_test):~ > d.vect map=archsites at PERMANENT
color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape
type=point,line,boundary,area icon=basic/circle size=5 layer=1 lsize=8
xref=left yref=center llayer=2 cat=1-10
This displays sites with cats 1-10
GRASS 6.4.svn (Spearfish60_test):~ > d.erase
type=point,line,boundary,area icon=basic/circle size=5 layer=2 lsize=8
This displays nothing
The labeling is worse. I can get labels from layer 1 in the GUI, but from
the command line to an xmon, I get...
The process has forked and you cannot use this CoreFoundation
functionality safely. You MUST exec().
Break on
__THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__()
to debug.
ERROR eof from graphics driver.
Trying to get labels from layer 2 gives me nothing.
I'm trying this with Spearfish, archsites (I've added columns), and the
dbf driver. I'm using a Mac OSX 10.5.5. But this seems to be a cross-
platform problem.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:2>
