[GRASS-dev] [GRASS GIS] #416: r.le.patch crashes on long filenames
trac at osgeo.org
Sun Dec 28 01:40:24 EST 2008
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.1
Component: Raster | Version: 6.3.0
Keywords: | Platform: Unspecified
Cpu: Unspecified |
(was:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=859&group_id=21)
r.le.patch crashes when using long filenames (gives a buffer overflow).
Using a short filename does not produce this error. Behaviour is
consistent across both linux as Mac OSX platforms.
Depending on the length of the filename r.le.patch crashes immediately or
the output of the module is garbage or not there. Again, this behaviour is
consistent on both linux as OSX.
Below you find a trace of a crash on a long filename.
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb7e2c558]
/lib/tls/i686/cmov/libc.so.6[0xb7e2a680]
/lib/tls/i686/cmov/libc.so.6[0xb7e29d68]
/lib/tls/i686/cmov/libc.so.6(_IO_default_xsputn+0xc8)[0xb7d9fa18]
/lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x3733)[0xb7d750c3]
/lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa7)[0xb7e29e17]
/lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb7e29d5d]
r.le.patch(open_files+0x33e)[0x804caee]
r.le.patch(patch_fore+0x82)[0x80546f2]
r.le.patch(main+0x519)[0x80568b9]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb7d48685]
r.le.patch[0x804ab31]
======= Memory map: ========
08048000-08064000 r-xp 00000000 08:01 2041981
/usr/lib/grass/bin/r.le.patch
08064000-08065000 r--p 0001b000 08:01 2041981
08065000-08066000 rw-p 0001c000 08:01 2041981
08af0000-08b35000 rw-p 08af0000 00:00 0 [heap]
b7cd2000-b7cdf000 r-xp 00000000 08:01 1237054 /lib/libgcc_s.so.1
b7cdf000-b7ce0000 r--p 0000c000 08:01 1237054 /lib/libgcc_s.so.1
b7ce0000-b7ce1000 rw-p 0000d000 08:01 1237054 /lib/libgcc_s.so.1
b7cf2000-b7d31000 r--p 00000000 08:01 2032550
/usr/lib/locale/en_US.utf8/LC_CTYPE
b7d31000-b7d32000 rw-p b7d31000 00:00 0
b7d32000-b7e8a000 r-xp 00000000 08:01 1254395
/lib/tls/i686/cmov/libc-2.8.90.so
b7e8a000-b7e8c000 r--p 00158000 08:01 1254395
b7e8c000-b7e8d000 rw-p 0015a000 08:01 1254395
b7e8d000-b7e90000 rw-p b7e8d000 00:00 0
b7e90000-b7eb4000 r-xp 00000000 08:01 1254403
/lib/tls/i686/cmov/libm-2.8.90.so
b7eb4000-b7eb5000 r--p 00023000 08:01 1254403
b7eb5000-b7eb6000 rw-p 00024000 08:01 1254403
b7eb6000-b7eca000 r-xp 00000000 08:01 2001395 /usr/lib/libz.so.1.2.3.3
b7eca000-b7ecc000 rw-p 00013000 08:01 2001395 /usr/lib/libz.so.1.2.3.3
b7ecc000-b7ecd000 rw-p b7ecc000 00:00 0
b7ed6000-b7ed7000 r--p 00000000 08:01 2039816
/usr/lib/locale/en_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES
b7ed7000-b7ede000 r--s 00000000 08:01 2384115 /usr/lib/gconv/gconv-
modules.cache
b7ede000-b7ee5000 r-xp 00000000 08:01 2359308
/usr/lib/grass/lib/libgrass_datetime.6.3.0.so
b7ee5000-b7ee6000 r--p 00006000 08:01 2359308
b7ee6000-b7ee7000 rw-p 00007000 08:01 2359308
b7ee7000-b7f32000 r-xp 00000000 08:01 2359324
/usr/lib/grass/lib/libgrass_gis.6.3.0.so
b7f32000-b7f33000 r--p 0004b000 08:01 2359324
b7f33000-b7f34000 rw-p 0004c000 08:01 2359324
b7f34000-b7f3c000 rw-p b7f34000 00:00 0
b7f3c000-b7f56000 r-xp 00000000 08:01 1237011 /lib/ld-2.8.90.so
b7f56000-b7f57000 r-xp b7f56000 00:00 0 [vdso]
b7f57000-b7f58000 r--p 0001a000 08:01 1237011 /lib/ld-2.8.90.so
b7f58000-b7f59000 rw-p 0001b000 08:01 1237011 /lib/ld-2.8.90.so
bfc43000-bfc58000 rw-p bffeb000 00:00 0 [stack]
Ticket URL: <http://trac.osgeo.org/grass/ticket/416>
