[GRASS-dev] Re: [GRASS GIS] #377: gis.m/Map Display fails to
handle vector layers with multiple databse layers
Michael Barton
michael.barton at asu.edu
Sun Dec 28 12:09:22 EST 2008
On Dec 28, 2008, at 7:14 AM, Moritz Lennert wrote:
> On Fri, December 26, 2008 18:17, Michael Barton wrote:
>> On Dec 26, 2008, at 9:59 AM, GRASS GIS wrote:
>>> well, and archsites at PERMANENT contains some elements in layer 2?
>>> v.category archsites at PERMANENT opt=report
>> Yes. I essentially duplicated the dbf for layer 1 and connected the
>> new dbf as layer 2, so I know it should be OK.
> Duplicating the dbf and connecting it (with v.db.connect) to another
> layer, does not create any features on that layer. To do that, you
> have to
> assign category values to features in that layer, with either
> v.category
> or v.digit.
> I think there is still a need to a much clearer and more detailed
> tutorial
> on layer handling, as this keeps popping up...
> Moritz
You're right. I forgot to do this step.
Michael
