[GRASS-dev] compile error in grass-6.4.0RC1/gui/wxpython
Otto Dassau
otto.dassau at gmx.de
Mon Dec 29 10:07:30 EST 2008
Dear developers,
I wanted to build GRASS 6.4.0 RC1 packages under OpenSuSE 11.0 and got errors in
grass-6.4.0RC1/gui/wxpython. I changed into the directory and tried with 'make'
again. I attached the error messages, maybe someone can have a look and help?
thanks a lot
Otto
make /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.html
make[4]: Entering directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/docs'
if [ "" != "" ] ; then GISRC=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI ; mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 wxGUI.tmp.html /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
../../../tools/mkhtml.sh: line 19: wxGUI.tmp.html: Keine Berechtigung
../../../tools/mkhtml.sh: line 23: wxGUI.tmp.html: Keine Berechtigung
grep: wxGUI.tmp.html: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 29: wxGUI.tmp.html.header: Keine Berechtigung
../../../tools/mkhtml.sh: line 42: wxGUI.tmp.html.header: Keine Berechtigung
mv: Aufruf von stat für âwxGUI.tmp.html.headerâ nicht möglich: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 65: wxGUI.tmp.html: Keine Berechtigung
/usr/bin/install: Aufruf von stat für âwxGUI.tmp.htmlâ nicht möglich: Datei oder Verzeichnis nicht gefunden
make[4]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/docs'
make[3]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/docs'
make[3]: Entering directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/docs'
make /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizing_Tool.html
if [ "" != "" ] ; then GISRC=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Vector_Digitizing_Tool.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Vector_Digitizing_Tool ; mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 wxGUI.Vector_Digitizing_Tool.tmp.html /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizing_Tool.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
../../../tools/mkhtml.sh: line 19: wxGUI.Vector_Digitizing_Tool.tmp.html: Keine Berechtigung
../../../tools/mkhtml.sh: line 23: wxGUI.Vector_Digitizing_Tool.tmp.html: Keine Berechtigung
grep: wxGUI.Vector_Digitizing_Tool.tmp.html: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 29: wxGUI.Vector_Digitizing_Tool.tmp.html.header: Keine Berechtigung
../../../tools/mkhtml.sh: line 42: wxGUI.Vector_Digitizing_Tool.tmp.html.header: Keine Berechtigung
mv: Aufruf von stat für âwxGUI.Vector_Digitizing_Tool.tmp.html.headerâ nicht möglich: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 65: wxGUI.Vector_Digitizing_Tool.tmp.html: Keine Berechtigung
/usr/bin/install: Aufruf von stat für âwxGUI.Vector_Digitizing_Tool.tmp.htmlâ nicht möglich: Datei oder Verzeichnis nicht gefunden
make /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html
if [ "" != "" ] ; then GISRC=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Attribute_Table_Manager.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Attribute_Table_Manager ; mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 wxGUI.Attribute_Table_Manager.tmp.html /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
../../../tools/mkhtml.sh: line 19: wxGUI.Attribute_Table_Manager.tmp.html: Keine Berechtigung
../../../tools/mkhtml.sh: line 23: wxGUI.Attribute_Table_Manager.tmp.html: Keine Berechtigung
grep: wxGUI.Attribute_Table_Manager.tmp.html: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 29: wxGUI.Attribute_Table_Manager.tmp.html.header: Keine Berechtigung
../../../tools/mkhtml.sh: line 42: wxGUI.Attribute_Table_Manager.tmp.html.header: Keine Berechtigung
mv: Aufruf von stat für âwxGUI.Attribute_Table_Manager.tmp.html.headerâ nicht möglich: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 65: wxGUI.Attribute_Table_Manager.tmp.html: Keine Berechtigung
/usr/bin/install: Aufruf von stat für âwxGUI.Attribute_Table_Manager.tmp.htmlâ nicht möglich: Datei oder Verzeichnis nicht gefunden
make /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.Nviz.html
if [ "" != "" ] ; then GISRC=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/bin:/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Nviz.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Nviz ; mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 wxGUI.Nviz.tmp.html /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html/wxGUI.Nviz.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
../../../tools/mkhtml.sh: line 19: wxGUI.Nviz.tmp.html: Keine Berechtigung
../../../tools/mkhtml.sh: line 23: wxGUI.Nviz.tmp.html: Keine Berechtigung
grep: wxGUI.Nviz.tmp.html: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 29: wxGUI.Nviz.tmp.html.header: Keine Berechtigung
../../../tools/mkhtml.sh: line 42: wxGUI.Nviz.tmp.html.header: Keine Berechtigung
mv: Aufruf von stat für âwxGUI.Nviz.tmp.html.headerâ nicht möglich: Datei oder Verzeichnis nicht gefunden
../../../tools/mkhtml.sh: line 65: wxGUI.Nviz.tmp.html: Keine Berechtigung
/usr/bin/install: Aufruf von stat für âwxGUI.Nviz.tmp.htmlâ nicht möglich: Datei oder Verzeichnis nicht gefunden
make[2]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/docs'
make -C scripts || echo /var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/scripts >> /usr/src/packages/BUILD/grass-6.4.0RC1/error.log
make[2]: Entering directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/scripts'
mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/etc/gui/scripts
/usr/bin/install -c d.rast3d /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/etc/gui/scripts/
make[2]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/scripts'
make -C vdigit || echo /var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/vdigit >> /usr/src/packages/BUILD/grass-6.4.0RC1/error.log
make[2]: Entering directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/vdigit'
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
mkdir: kann Verzeichnis âOBJ.i686-pc-linux-gnuâ nicht anlegen: Keine Berechtigung
make[2]: [OBJ.i686-pc-linux-gnu] Fehler 1 (ignoriert)
c++ -I/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/include -g -O2 -fPIC -I/usr/include -I/usr/include/python2.5 -I/usr/include/python2.5 -fno-strict-aliasing -DNDEBUG -O2 -march=i586 -mtune=i686 -fmessage-length=0 -Wall -D_FORTIFY_SOURCE=2 -fstack-protector -g -fwrapv -I/usr/lib/wxPython-2.8.8.1-gtk2-unicode/lib/wx/include/gtk2-unicode-debug-2.8 -I/usr/lib/wxPython-2.8.8.1-gtk2-unicode/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXDEBUG__ -D__WXGTK__ -pthread -DPACKAGE=\""grasslibs"\" -I/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/cats.o -c cats.cpp
cats.cpp:18:24: error: grass/dbmi.h: Datei oder Verzeichnis nicht gefunden
In file included from cats.cpp:21:
driver.h:29:23: error: grass/gis.h: Datei oder Verzeichnis nicht gefunden
driver.h:30:24: error: grass/Vect.h: Datei oder Verzeichnis nicht gefunden
driver.h:68: error: âBOUND_BOXâ does not name a type
cats.cpp: In member function âint Digit::InitCats()â:
cats.cpp:47: error: âVect_get_num_dblinksâ was not declared in this scope
cats.cpp:49: error: âVect_get_dblinkâ was not declared in this scope
cats.cpp:51: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:35: error: forward declaration of âstruct field_infoâ
cats.cpp:51: error: âPORT_INT_MINâ was not declared in this scope
cats.cpp:56: error: âVect_cidx_get_num_fieldsâ was not declared in this scope
cats.cpp:57: error: âG_debugâ was not declared in this scope
cats.cpp:60: error: âVect_cidx_get_field_numberâ was not declared in this scope
cats.cpp:61: error: âVect_cidx_get_num_cats_by_indexâ was not declared in this scope
cats.cpp:66: error: âVect_cidx_get_cat_by_indexâ was not declared in this scope
cats.cpp:77: error: âPORT_INT_MINâ was not declared in this scope
cats.cpp: In member function âint Digit::GetCategory(int)â:
cats.cpp:98: error: âG_debugâ was not declared in this scope
cats.cpp: In member function âint Digit::SetCategory(int, int)â:
cats.cpp:127: error: âG_debugâ was not declared in this scope
cats.cpp: In member function âstd::map<int, std::vector<int, std::allocator<int> >, std::less<int>, std::allocator<std::pair<const int, std::vector<int, std::allocator<int> > > > > Digit::GetLineCats(int)â:
cats.cpp:169: error: invalid use of incomplete type âstruct ilistâ
driver.h:52: error: forward declaration of âstruct ilistâ
cats.cpp:176: error: invalid use of incomplete type âstruct ilistâ
cats.cpp:179: error: âVect_line_aliveâ was not declared in this scope
cats.cpp:184: error: âVect_new_cats_structâ was not declared in this scope
cats.cpp:186: error: âVect_read_lineâ was not declared in this scope
cats.cpp:187: error: âVect_destroy_cats_structâ was not declared in this scope
cats.cpp:192: error: invalid use of incomplete type âstruct line_catsâ
driver.h:64: error: forward declaration of âstruct line_catsâ
cats.cpp:193: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:195: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:197: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:200: error: âVect_destroy_cats_structâ was not declared in this scope
cats.cpp: In member function âint Digit::SetLineCats(int, int, std::vector<int, std::allocator<int> >, bool)â:
cats.cpp:227: error: invalid use of incomplete type âstruct ilistâ
cats.cpp:233: error: invalid use of incomplete type âstruct ilistâ
cats.cpp:239: error: âVect_line_aliveâ was not declared in this scope
cats.cpp:244: error: âVect_new_line_structâ was not declared in this scope
cats.cpp:245: error: âVect_new_cats_structâ was not declared in this scope
cats.cpp:246: error: âVect_read_lineâ was not declared in this scope
cats.cpp:248: error: âVect_destroy_line_structâ was not declared in this scope
cats.cpp:249: error: âVect_destroy_cats_structâ was not declared in this scope
cats.cpp:257: error: âVect_cat_setâ was not declared in this scope
cats.cpp:260: error: âVect_field_cat_delâ was not declared in this scope
cats.cpp:263: error: âG_debugâ was not declared in this scope
cats.cpp:270: error: âVect_rewrite_lineâ was not declared in this scope
cats.cpp:285: error: invalid use of incomplete type âstruct ilistâ
cats.cpp:288: error: âVect_destroy_line_structâ was not declared in this scope
cats.cpp:289: error: âVect_destroy_cats_structâ was not declared in this scope
cats.cpp: In member function âint Digit::CopyCats(std::vector<int, std::allocator<int> >, std::vector<int, std::allocator<int> >, bool)â:
cats.cpp:312: error: âVect_new_line_structâ was not declared in this scope
cats.cpp:313: error: âVect_new_cats_structâ was not declared in this scope
cats.cpp:322: error: âVect_line_aliveâ was not declared in this scope
cats.cpp:325: error: âVect_read_lineâ was not declared in this scope
cats.cpp:335: error: âVect_line_aliveâ was not declared in this scope
cats.cpp:344: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:346: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:352: error: âdbDriverâ was not declared in this scope
cats.cpp:352: error: âdriverâ was not declared in this scope
cats.cpp:353: error: âdbHandleâ was not declared in this scope
cats.cpp:353: error: expected `;' before âhandleâ
cats.cpp:354: error: âdbCursorâ was not declared in this scope
cats.cpp:354: error: expected `;' before âcursorâ
cats.cpp:355: error: âdbTableâ was not declared in this scope
cats.cpp:355: error: âtableâ was not declared in this scope
cats.cpp:356: error: âdbColumnâ was not declared in this scope
cats.cpp:356: error: âcolumnâ was not declared in this scope
cats.cpp:357: error: âdbValueâ was not declared in this scope
cats.cpp:357: error: âvalueâ was not declared in this scope
cats.cpp:358: error: âdbStringâ was not declared in this scope
cats.cpp:358: error: expected `;' before âstmtâ
cats.cpp:362: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:364: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:364: error: âVect_get_fieldâ was not declared in this scope
cats.cpp:367: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:371: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:350: error: forward declaration of âstruct field_infoâ
cats.cpp:371: error: âdb_start_driverâ was not declared in this scope
cats.cpp:373: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:377: error: âhandleâ was not declared in this scope
cats.cpp:377: error: âdb_init_handleâ was not declared in this scope
cats.cpp:378: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:378: error: âdb_set_handleâ was not declared in this scope
cats.cpp:379: error: âdb_open_databaseâ was not declared in this scope
cats.cpp:379: error: âDB_OKâ was not declared in this scope
cats.cpp:380: error: âdb_shutdown_driverâ was not declared in this scope
cats.cpp:381: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:385: error: âstmtâ was not declared in this scope
cats.cpp:385: error: âdb_init_stringâ was not declared in this scope
cats.cpp:387: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:387: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:388: error: âdb_set_stringâ was not declared in this scope
cats.cpp:390: error: âcursorâ was not declared in this scope
cats.cpp:390: error: âDB_SEQUENTIALâ was not declared in this scope
cats.cpp:390: error: âdb_open_select_cursorâ was not declared in this scope
cats.cpp:390: error: âDB_OKâ was not declared in this scope
cats.cpp:391: error: âdb_close_databaseâ was not declared in this scope
cats.cpp:392: error: âdb_shutdown_driverâ was not declared in this scope
cats.cpp:393: error: âdb_get_stringâ was not declared in this scope
cats.cpp:398: error: âcursorâ was not declared in this scope
cats.cpp:398: error: âdb_get_cursor_tableâ was not declared in this scope
cats.cpp:399: error: âdb_get_table_number_of_columnsâ was not declared in this scope
cats.cpp:401: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:406: error: âDB_NEXTâ was not declared in this scope
cats.cpp:406: error: âdb_fetchâ was not declared in this scope
cats.cpp:406: error: âDB_OKâ was not declared in this scope
cats.cpp:407: error: âdb_close_databaseâ was not declared in this scope
cats.cpp:408: error: âdb_shutdown_driverâ was not declared in this scope
cats.cpp:416: error: âdb_append_stringâ was not declared in this scope
cats.cpp:418: error: âdb_get_table_columnâ was not declared in this scope
cats.cpp:419: error: âdb_get_column_nameâ was not declared in this scope
cats.cpp:419: error: invalid use of incomplete type âstruct field_infoâ
cats.cpp:421: error: âdb_append_stringâ was not declared in this scope
cats.cpp:425: error: âdb_get_column_valueâ was not declared in this scope
cats.cpp:426: error: âvalue_stringâ was not declared in this scope
cats.cpp:426: error: âdb_convert_column_value_to_stringâ was not declared in this scope
cats.cpp:427: error: âdb_test_value_isnullâ was not declared in this scope
cats.cpp:428: error: âdb_append_stringâ was not declared in this scope
cats.cpp:430: error: âdb_get_column_sqltypeâ was not declared in this scope
cats.cpp:430: error: âdb_sqltype_to_Ctypeâ was not declared in this scope
cats.cpp:431: error: âDB_C_TYPE_STRINGâ was not declared in this scope
cats.cpp:432: error: âdb_get_stringâ was not declared in this scope
cats.cpp:432: error: âdb_append_stringâ was not declared in this scope
cats.cpp:434: error: âdb_get_stringâ was not declared in this scope
cats.cpp:435: error: âdb_append_stringâ was not declared in this scope
cats.cpp:440: error: âdb_append_stringâ was not declared in this scope
cats.cpp:442: error: âdb_execute_immediateâ was not declared in this scope
cats.cpp:442: error: âDB_OKâ was not declared in this scope
cats.cpp:443: error: âdb_close_databaseâ was not declared in this scope
cats.cpp:444: error: âdb_shutdown_driverâ was not declared in this scope
cats.cpp:445: error: âdb_get_stringâ was not declared in this scope
cats.cpp:449: error: âdb_close_databaseâ was not declared in this scope
cats.cpp:450: error: âdb_shutdown_driverâ was not declared in this scope
cats.cpp:453: error: invalid use of incomplete type âstruct line_catsâ
cats.cpp:453: error: âVect_cat_setâ was not declared in this scope
cats.cpp:458: error: âVect_rewrite_lineâ was not declared in this scope
cats.cpp:463: error: âG_debugâ was not declared in this scope
cats.cpp:469: error: âVect_destroy_line_structâ was not declared in this scope
cats.cpp:470: error: âVect_destroy_cats_structâ was not declared in this scope
make[2]: *** [OBJ.i686-pc-linux-gnu/cats.o] Fehler 1
make[2]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/vdigit'
make -C nviz || echo /var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/nviz >> /usr/src/packages/BUILD/grass-6.4.0RC1/error.log
make[2]: Entering directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/nviz'
make /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/etc/wxpython/nviz/_grass6_wxnviz.so /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/etc/wxpython/nviz/grass6_wxnviz.py
make[3]: Entering directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/nviz'
make[3]: [OBJ.i686-pc-linux-gnu] Fehler 1 (ignoriert)
c++ -I/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/include -g -O2 -fPIC -I/usr/include -I/usr/include/python2.5 -I/usr/include/python2.5 -fno-strict-aliasing -DNDEBUG -O2 -march=i586 -mtune=i686 -fmessage-length=0 -Wall -D_FORTIFY_SOURCE=2 -fstack-protector -g -fwrapv -I/usr/lib/wxPython-2.8.8.1-gtk2-unicode/lib/wx/include/gtk2-unicode-debug-2.8 -I/usr/lib/wxPython-2.8.8.1-gtk2-unicode/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXDEBUG__ -D__WXGTK__ -pthread -DPACKAGE=\""grasslibs"\" -I/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/change_view.o -c change_view.cpp
In file included from change_view.cpp:19:
nviz.h:7:23: error: grass/gis.h: Datei oder Verzeichnis nicht gefunden
nviz.h:8:24: error: grass/nviz.h: Datei oder Verzeichnis nicht gefunden
nviz.h:9:25: error: grass/gsurf.h: Datei oder Verzeichnis nicht gefunden
nviz.h:10:27: error: grass/gstypes.h: Datei oder Verzeichnis nicht gefunden
nviz.h:32: error: ISO C++ forbids declaration of ânv_dataâ with no type
nviz.h:32: error: expected â;â before â*â token
change_view.cpp: In member function âint Nviz::ResizeWindow(int, int)â:
change_view.cpp:34: error: âNviz_resize_windowâ was not declared in this scope
change_view.cpp:37: error: âG_debugâ was not declared in this scope
change_view.cpp: In member function âstd::vector<double, std::allocator<double> > Nviz::SetViewDefault()â:
change_view.cpp:54: error: âNviz_get_exagâ was not declared in this scope
change_view.cpp:56: error: âdataâ was not declared in this scope
change_view.cpp:57: error: âNviz_change_exagâ was not declared in this scope
change_view.cpp:60: error: âNviz_get_exag_heightâ was not declared in this scope
change_view.cpp:66: error: âG_debugâ was not declared in this scope
change_view.cpp: In member function âint Nviz::SetView(float, float, float, float, float)â:
change_view.cpp:84: error: âdataâ was not declared in this scope
change_view.cpp:85: error: âNviz_set_viewpoint_heightâ was not declared in this scope
change_view.cpp:87: error: âNviz_set_viewpoint_positionâ was not declared in this scope
change_view.cpp:89: error: âNviz_set_viewpoint_twistâ was not declared in this scope
change_view.cpp:91: error: âNviz_set_viewpoint_perspâ was not declared in this scope
change_view.cpp:94: error: âG_debugâ was not declared in this scope
change_view.cpp: In member function âint Nviz::SetZExag(float)â:
change_view.cpp:110: error: âdataâ was not declared in this scope
change_view.cpp:110: error: âNviz_change_exagâ was not declared in this scope
change_view.cpp:112: error: âG_debugâ was not declared in this scope
make[3]: *** [OBJ.i686-pc-linux-gnu/change_view.o] Fehler 1
make[3]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/nviz'
make[2]: *** [install_nviz] Fehler 2
make[2]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/nviz'
make[1]: Leaving directory `/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython'
dassau at linux-magu:/var/tmp/build-root/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython>
