[GRASS-dev] Re: [GRASS GIS] #31: NVIZ issues in GRASS6.x
Michael Barton
michael.barton at asu.edu
Wed Dec 31 17:50:22 EST 2008
> Reporter: clerici | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: major | Milestone: 6.4.0
> Component: NVIZ | Version: svn-develbranch6
> Resolution: | Keywords: nviz
> Platform: Unspecified | Cpu: Unspecified
> Changes (by marisn):
> * version: 6.2.3 => svn-develbranch6
> Comment:
> Seems like minor issues are fixed. Left over issues are complex ones
> and
> may be related to C bugs or improper C/TCL interaction. [[BR]]
> Steps to reproduce 5:
> nviz elevation=elevation.dem at PERMANENT [[BR]]
> Add new raster surface as constant ("New constant"->enter value 3000),
> uncheck "use as color"[[BR]]
> Click "DRAW CURRENT" -> new gray surface is displayed on top of
> elevation.dem surface (OK)[[BR]]
> Change new constant surface transparency, set it to constant (i.e.
> 30)[[BR]]
> Click "DRAW CURRENT" once -> new surface gets transparent (OK)[[BR]]
> Click "DRAW CURRENT" for second time -> new surface is not transparent
> anymore (BUG)[[BR]]
> Click "CLEAR" and then "DRAW" -> new surface is displayed below
> elevation.dem (BUG)[[BR]]
> Click "CLEAR" and then "DRAW CURRENT" -> only new raster surface is
> displayed. elevation.dem is missing (WTF?)[[BR]]
> Change view and then click "DRAW CURRENT" -> new surface is
> transparent
> and on top of elevation.dem(OK)
The DRAW CURRENT button calls "Nsurf_draw_one". I think this is a call
to the C part of NVIZ. I wish there was some kind of description of
which commands are actually useable and what their syntax is.
Michael
