[GRASS-dev] [GRASS GIS] #33: config.in: cairo and ffmpeg checks
Fri Feb 1 07:21:05 EST 2008
Lars Ahlzen wrote:
> >  we should finish adding Cairo support by building it into the ./configure
> >  script.
> >  the attached patch also adds an extra test needed for ffmpeg.
> >  I do not know much about autoconf and ./configure scripts so I don't claim
> >  that the attached patch will work, but it should be a good starting point.
> >  Hamish
> Thanks (both you Hamish and Glynn)!
> The --with-cairo configure option seems to work well (I tried it after
> Glynn's update to use pkg-config).
It appears that assigning ownership to myself means that the update
message doesn't get sent to the list.
It would be nice if that can be changed; IMHO, all tracker messages
should be copied to the list.
> For completeness, below is a small patch to update the Cairo monitor
> documentation to reflect this change, that perhaps someone can apply?
I've made the changes.
I couldn't apply the patch directly, due to reformatting by your mail
client. Ideally, patches should be sent as attachments rather than
pasted into the message body.
