[GRASS-dev] lib fn to convert int color number to RGB values?
Ivan Shmakov
ivan at theory.asu.ru
Fri Feb 1 06:55:54 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>>> The GRASS libraries are fundamentally designed to be used in
>>> "one-shot" modules. Errors are handled by printing a message then
>>> exiting. Variables are either initialised at startup from the .data
>>> and .bss segments or are initialised upon first use. Memory doesn't
>>> get explicitly de-allocated, as the operating system will do that
>>> when the module terminates.
>> Thanks for the clarification, but isn't the main question in whether
>> there's any interest for it to be changed?
> Oh, someone was to suddently turn up with a re-factored version where
> all library functions behaved as desired and all modules had been
> re-written accordingly, I'm sure that everyone would be happy.
> [Assuming that you achieve this without significantly increasing the
> job of writing modules. Minimising the effort involved in writing
> modules takes precedence over most other considerations.]
Yes.
> The main problem here is that you would need to re-write all of the
> lower-level functions to return (which means that they need to
> perform clean-up in the event of an error), with the non-returning
> versions implemented as a thin veneer at the top level.
Yes, most probably.
> I'm assuming that you're willing to at least leave malloc() errors as
> fatal, otherwise you will have to re-write almost everything.
I've already noticed that. I don't feel that a change like this
one is going to become feasible in any near future.
> What about low-level I/O errors (EIO, ENOSPC, EPERM etc)? If e.g. EIO
> while reading $GISRC needs to be propagated up to the caller, any
> function which ends up calling G_getenv() would need to be
> re-written, and that's almost as big an issue as malloc()
> errors. Similar issues exist for WIND, VAR and PROJ_INFO, and
> possibly for some map elements.
I haven't yet looked at the code for these. Most probably
you're right.
>> BTW, shouldn't G_find_cell () be marked as ``deprecated'' in
>> `include/gisdefs.h' (if the compiler permits it), so that a warning
>> will be issued for each its use?
> There is a valid use for it, i.e. if you specifically want qualified
> names to be split into map and mapset parts.
> For 7.x, I would like to dispense with those functions altogether for
> most modules. I.e. G_open_cell_old() etc would simply take the
> (possibly qualified) name as an argument. Most modules wouldn't need
> to know anything about mapsets; they would just pass the the value of
> the ->answer field from the Option structure directly to the libgis
> functions.
> Most library functions would behave likewise, passing map names
> around without needing to know the details. Only the lowest-level
> functions which directly access files (e.g. G_{open,fopen}_*) would
> need to decompose map names.
Oh, but that sounds like a... rewrite!
... And I'm pretty sure that such a change will bring clarity
upon both the library interface and its callers.
