[GRASS-dev] Scripting programming: directory structure of GRASS
Jachym Cepicky jachym.cepicky at gmail.com
Fri Feb 1 12:16:56 EST 2008
http://grass.osgeo.org/grass63/manuals/html63_user/variables.html#enviro
GRASS_ADDON_PATH
[grass startup script]
  allows to specify additional paths to local GRASS modules extra to
standard distribution.
so, if you set $GRASS_ADDON_PATH (e.g. in ~/.grass.bashrc) and put your
program there, it should work
jachym
roberto.marzocchi píše v Pá 01. 02. 2008 v 16:30 +0100:
> Hi,
> I'm writing a script for Grass.
> I've a problem with the directory structure of GRASS.
> I know where is the place of script: ($GISBASE/scripts).
> But my script  use some fortran-codes, I compile
> this codes with gfortran, and I don't know where's the correct directory
> for the executable compiled.
> Thank in advanced!
> Roberto
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080201/7879dbef/attachment.bin
