[GRASS-dev] Autoconf 2.13
Hamish
hamish_b at yahoo.com
Mon Feb 4 00:13:04 EST 2008
Paul wrote:
> There were also a lot of improvements and tidying recently with
> regard to making parallel builds work and stopping needless
> regeneration of HTML documentation on every compile.
re. "stopping needless regeneration of HTML documentation on every
compile":
I am still not happy with the current solution. For example:
# help page updated from 2 days ago
$ cd vector/v.extract
$ svn up
U description.html
Updated to revision 29941.
$ make
make[2]:
`/usr/local/src/grass/svn/grass63/dist.i686-pc-linux-gnu/docs/html/v.extract.html'
is up to date.
(& the help page is not updated)
No, v.extract.html is not up to date. Only the top --html-description
part is up to date.
$ touch main.c
$ make
make htmlcmd
make[1]: Entering directory
.../../tools/mkhtml.sh v.extract ; mkdir -p
/usr/local/src/grass/svn/grass63/dist.i686-pc-linux-gnu/docs/html ;
/usr/bin/install -c -m 644 v.extract.tmp.html
(help page is updated)
Changes to either the module's G_parser() definition or
description.html should trigger a rebuild of the help page, somehow.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
