[GRASS-dev] erratic behavior of v.in.ascii with WinGRASS
Helena Mitasova hmitaso at unity.ncsu.edu
Mon Feb 4 22:47:11 EST 2008
Michael,
my Mac definitely does not like fs=|
it imports it correctly without it (as it i the default separator)
or when it is "|"
Helena
g.region rast=elevation
  v.in.ascii schools_el_lu.txt output=schools_lutest format=point
fs=| skip=0 x=1 y=2 z=0 cat=3
Scanning input for column types ...
Maximum input row length: 89
Maximum number of columns: 1
Minimum number of columns: 1
ERROR: y column number > minimum last column number
        (incorrect field separator?)
fs="|" skip=0 x=1 y=2 z=0 cat=3
Maximum number of columns: 7
Minimum number of columns: 5
Importing points ...
Populating table...
Building topology ...
167 primitives registered
Building areas:  100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids:  100%
Topology was built.
Number of nodes     :   167
Number of primitives:   167
Number of points    :   167
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
v.in.ascii complete.
On Feb 4, 2008, at 10:23 PM, Helena Mitasova wrote:
> On Feb 4, 2008, at 9:45 PM, Michael Barton wrote:
>>>> I've run into a problem running v.in.ascii for WinGRASS
>>>> importing an
>>>> ASCII points file. Sometimes it works OK. Other times, it causes a
>>>> Windows dbf.exe error but still gets the job done. In most
>>>> cases, it
>>>> causes a dbf.exe error and only imports the first point--with a
>>>> coor
>>>> error.
>>>> Here are a couple of other pieces of information.
>>> can you 1) run it with 'g.gisenv DEBUG=5' and 2) make the input file
>>> and exact command line used available.
>>> how about if you skip DB creation with '-t'?
>>> Hamish
>> We've used several files to test. But the main one is from the N.
>> Carolina demo data set, external files for import <http://
>> skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/ncexternal/
>> schools_el_lu.txt>.
> that file was actually output from GRASS - this is the command:
> r.what -f elevation,landuse96_28m null=-9999 < schools.txt >
> schools_el_lu.txt
> the original file is here (I assume that one works):
> http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/
> ncexternal/schools.txt
> Apparently I haven't tried to import it. It was probably generated
> on Mac.
> I can try it out and report back,
> Helena
>> This is a messy dataset, which may be part of the cause. But OTOH,
>> it should behave the same way on all platforms and not cause a
>> Windows dbf.exe error.
>> v.in.ascii input=/Users/cmbarton/schools_el_lu.txt
>> output=schools_lu format=point fs=| skip=0 x=1 y=2 z=0 cat=3
>> I just tried it and saw it flash a malloc and dbmi error before it
>> crashed the GUI
>> I'll try the debug on my Mac. I don't think that will work on
>> Windows.
>> Michael
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
