[GRASS-dev] [GRASS GIS] #36: v.generalize Assertion failed.
GRASS GIS trac at osgeo.org
Tue Feb 5 09:12:19 EST 2008
 Reporter:  marisn   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.4.0
Component:  default  |     Version:  svn-trunk
 Keywords:           |
 (gdb) run -r input=cont_4144 at PERMANENT output=cont_4144_general type=line
 method=hermite threshold=3 look_ahead=7 reduction=50 slide=0.5
 angle_thresh=3 degree_thresh=0 closeness_thresh=0 betweeness_thresh=0
 alpha=1.0 beta=1.0 iterations=1 layer=1 --overwrite
 Starting program: /home/maris/soft/grass_trunk/dist.x86_64-unknown-linux-
 gnu/bin/v.generalize -r input=cont_4144 at PERMANENT output=cont_4144_general
 type=line method=hermite threshold=3 look_ahead=7 reduction=50 slide=0.5
 [Thread debugging using libthread_db enabled]
 [New Thread 0x2b33d27a2ce0 (LWP 16093)]
 WARNING: Vector map <cont_4144_general> already exists and will be
          overwritten
 Generalization (hermite)...
  100%
 Building topology for vector map <cont_4144_general>...
 Registering lines: v.generalize: index.c:157: RTreeInsertRect: Assertion
 `r->boundary[i] <= r->boundary[3+i]' failed.
 Program received signal SIGABRT, Aborted.
 [Switching to Thread 0x2b33d27a2ce0 (LWP 16093)]
 0x00002b33cf082b45 in raise () from /lib64/libc.so.6
 (gdb) bt
 #0  0x00002b33cf082b45 in raise () from /lib64/libc.so.6
 #1  0x00002b33cf0840e0 in abort () from /lib64/libc.so.6
 #2  0x00002b33cf07c07f in __assert_fail () from /lib64/libc.so.6
 #3  0x00002b33ce27df3e in RTreeInsertRect (R=<value optimized out>,
 Tid=<value optimized out>, Root=0x7fffddb5fa50, Level=0)
     at index.c:157
 #4  0x00002b33ce075559 in dig_spidx_add_line (Plus=0x7fffddb5f840,
 line=12, box=0x7fffddb5f5b0) at spindex.c:128
 #5  0x00002b33ce071561 in dig_add_line (plus=0x7fffddb5f840, type=2,
 Points=0x74ad50, offset=105753) at plus_line.c:133
 #6  0x00002b33cd177cab in Vect_build_nat (Map=0x7fffddb5f830, build=4,
 msgout=0x2b33cf391760) at build_nat.c:501
 #7  0x00002b33cd1767a3 in Vect_build_partial (Map=0x7fffddb5f830, build=4,
 msgout=0x2b33cf391760) at build.c:152
 #8  0x0000000000404e23 in main (argc=19, argv=0xfffffffe) at main.c:489
 OS: OpenSuSE 10.3 64bit
 GRASS: svn-trunk rev. 29954
Ticket URL: <http://trac.osgeo.org/grass/ticket/36>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
