[GRASS-dev] MASK seems to be ignored
Michael Barton
michael.barton at asu.edu
Tue Feb 5 12:45:48 EST 2008
On Feb 5, 2008, at 9:48 AM, Patton, Eric wrote:
>> The way I understand it is that a MASK will affect all subsequent
>> *read* operations for processing a raster map. That is...
>> r.mapcalc 'newmap=oldmap'
>> ...will just produce an unaltered copy of oldmap without a MASK; with
>> a MASK it will produce a copy of oldmap only in the area of MASK.
>> MASK will not affect the display. It is for map processing.
>> Michael
> It seems that the current mask does affect the display, though.
> I've placed three
> screenshots on ftp://gsca.nrcan.gc.ca/outgoing/Patton. The 'Before'
> image is the
> full extent of my input raster; I zoomed into a small region in the
> display,
> set the region to that of the display extent, and created a mask
> using r.mapcalc !isnull(MAP).
> I then zoomed back to my original display extent, set the region
> back to that of
> the display, and redrew the display, the output of which is the
> 'After' image.
> The display is being clipped by the current mask.
Eric,
You are right. I stand corrected (or sit in this case).
Michael
> ~ Eric.
