[GRASS-dev] [GRASS GIS] #39: r.in.srtm fails to validate zip files
GRASS GIS trac at osgeo.org
Tue Feb 5 17:18:10 EST 2008
 Reporter:  kyngchaos  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.3.0
Component:  default    |     Version:  unspecified
 Keywords:             |
 r.in.srtm uses "file -ib" on the zip file to check if it has the correct
 mime type.  "-i" seems to be a very ambiguous way to specify the mime
 flag.  The BSD version of file (at least on OSX) uses "-i" for the "do no
 classify" regular files option, and "-I" (uppercase) for the mime option,
 though has "-i" for mime listed as a legacy option.  GNU file and old UNIX
 versions use "-i" for the mime option.  SUS does not have mime as a
 minimum option to support.
 It looks like all have  the extended "--mime" flag.  Attached is a patch
 to use that flag.  There should probably be a way to handle the
 possibility of a system having a "file" command without any mime flag, but
 I don't know how to handle that, and it may not be critical.
Ticket URL: <http://trac.osgeo.org/grass/ticket/39>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
