[GRASS-dev] g.mapset calling D_erase() ?
Ivan Shmakov ivan at theory.asu.ru
Thu Feb 7 22:32:48 EST 2008
>>>>> Hamish  <hamish_b at yahoo.com> writes:
 > Hi, g.mapset calls D_erase(), should it?
	My opinion is that it shouldn't.
	I'd say that to ease both the maintenance and learning of GRASS
	the modules should have as less side effects as possible.
 > Obviously the display will be stale after changing the mapset, but
 > for me a typical use is to drop into the PERMANENT mapset for a
 > minute to adjust something (say g.region -s or g.setproj), then back
 > to my normal session.
 > any thoughts? Should g.mapset be like a soft-reboot of the GIS or a
 > simple call to g.gisenv? Is it worth it to add a flag to g.mapset to
 > skip the D_erase()?
	Since this behaviour isn't probably relied upon, I think it
	isn't necessary.
 > I guess it's a similar issue to GRASS 5 leaving xmons open after the
 > main program quits.
 > ?, Hamish
