[GRASS-dev] ps driver and polygon fill
Moritz Lennert
mlennert at club.worldonline.be
Sat Feb 9 12:42:57 EST 2008
On Fri, February 8, 2008 22:59, Glynn Clements wrote:
> Moritz Lennert wrote:
>> Trying to use d.vect.chart with the PS driver, I get circles which are
>> filled by lines. See [1].
> d.vect.chart? Or d.vect.thematic?
d.vect.chart
>> I remember there was some discussion about this before, but is this
>> inevitable in the current state of the display system and the PS driver
> No. It's perfectly possible to draw filled areas as filled areas. But
> if a module decides to do its own filling by telling the driver to
> draw lots of lines, then you get lots of lines. The display drivers
> can't "undo" any rasterisation performed by the module.
> IOW, it's a problem with the modules, or with specific libraries which
> they use, not with the display system.
Ok, then I´ll look into the code to see what´s going on.
Moritz
> Glynn Clements <glynn at gclements.plus.com>
