[GRASS-dev] Re: [GRASS-user] build grass on osx 10.5-leopard
(can't find opengl lib)
William Kyngesburye
woklist at kyngchaos.com
Sat Feb 9 17:24:28 EST 2008
On Feb 9, 2008, at 3:00 PM, Glynn Clements wrote:
>> As explained in the macosx readme
>> i need to modify the files :
>> grass_trunk/include/Make/Platform.make.in
>> grass_trunk/configure
>> what i done :
>> in Platform.make.in changed the line 160 to :
>> OPENGLLIB = -dylib_file /usr/X11/lib/libGL.dylib:/usr/X11/
>> lib/libGL.dylib -undefined dynamic_lookup
>> but in the file :
>> configure
>> here i'm having problems to undstand what needs a modify, i tried to
>> replace all the :
>> " -lGL "
>> with :
>> " -dylib_file /usr/X11/lib/libGL.dylib:/usr/X11/lib/libGL.dylib "
>> or
>> " -/usr/X11/lib/libGL.dylib:/usr/X11/lib/libGL.dylib "
>> ....or again :
>> " -/usr/X11/lib/libGL.dylib "
>> but the ./configure ... ... fail
>> configure: error: *** Unable to locate OpenGL library.
>> obviously (apologize me for these) i'm wrong to modify the configure
>> file.
You left out the "-undefined dynamic_lookup" in the replacement. And
be sure to find with a "whole words" option (ie in TextWrangler/
BBEdit), or it will find other things it shouldn't.
> If configure can't detect OpenGL itself, use --without-opengl then
> modify include/config.h and include/Make/Platform.make once configure
> has finished.
Hmm, that's sounds like a better option than messing around with
configure. (grr, I hope Apple fixes their linker soon.)
I'll look into the details that would be needed.
PS. I have a bug report for this on the GForge tracker:
http://wald.intevation.org/tracker/?func=detail&aid=536&group_id=21&atid=204
More of an informational bug, really, since it's an Apple linker
problem. But if Apple can't fix it soon, a workaround in configure
may be necessary.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a
bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
