[GRASS-dev] Re: [GRASS GIS] #38: configure.in: wxwidgets and python checks
Martin Landa landa.martin at gmail.com
Sat Feb 9 19:50:49 EST 2008
HI,
2008/2/9, Glynn Clements <glynn at gclements.plus.com>:
[snip]
> I wouldn't assume that you can compile Python extensions without it.
> For simple libraries, it's enough to know what the header and library
> files are called and to let the user specify where they can be found.
> For complex "subsystems", this is often inadequate. You may need any
> number of additional libraries as well as specific compiler and linker
> switches, many of which will be at least platform-dependent and
> possibly worse (consider Gentoo, where everything gets built from
> source with any number of user-selectable options).
> E.g. on my system:
>         $ python-config --cflags
>         -I/usr/include/python2.4 -I/usr/include/python2.4 -fno-strict-aliasing -DNDEBUG
> Okay, so --with-python-includes=-I/usr/include/python2.4 might
> suffice, depending upon whether or not the code actually uses anything
> which violates C aliasing rules and/or the extent to which the
> compiler takes advantage of them (I presume the -fno-strict-aliasing
> flag is there for a reason).
> But that's on my system. There's no telling what additional flags it
> might need on some other system.
thanks for clarification, I modified the patch to require
python-config (or python$PYVERSION-config), see
http://trac.osgeo.org/grass/attachment/ticket/38/configure_wx-2.diff
If no objections I will commit to SVN.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
