[GRASS-dev] Re: [GRASS GIS] #39: r.in.srtm fails to validate zip files
Hamish hamish_b at yahoo.com
Sun Feb 10 18:45:51 EST 2008
Hamish:
> > re "why was it changed" in r19303: it never used `zip` to test, it
> > was  using `ls` to look for a file with a .zip extension. (input=
> > refers to the tile name not the file name)
> >  for one thing "echo $foo.zip | grep zip" was always true.
oops, wrong. that was used as a 'if [ -f ${FILE}.zip ] ;'  test.
Not like echo as the file wasn't guaranteed to be there.
> > Perhaps the reason for the test had to do with downloaders
> > creating incomplete or 0 byte files, or having wrongly named files?
No, the module built the input filename internally, and was checking
that it came up with a correct filename. Getting mime type from `file`
was just a more advanced form of that.
Glynn:
> If incomplete downloads are an issue,
probably not. It will exit with an error if the unzip step fails.
> >  I've removed `file` and added a call to `unzip -t` in 6.3 trunk.
and I think that should be fine.
> > waiting to backport to 6.3.0's branch and close the bug until
> > someone tests the change please.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
