R: [GRASS-dev] GEOS, PostgreSQL and SQLite: needed in GDAL?
Moritz Lennert
mlennert at club.worldonline.be
Mon Feb 11 05:20:46 EST 2008
On 08/02/08 11:35, marco.pasetti at alice.it wrote:
> Hi Moritz,
> >Hope this clarifies the issue a bit.
> Yes! a lot, not a bit!
> I need to import Arc-Info ASCII data, using r.in.arc, so I think I will
> be able to do that even without PostgreSQL and SQLite!
> And what about GEOS?
AFAIK, GRASS does not use GEOS at all.
Moritz
> Thanks,
> Marco
> *Da:* Moritz Lennert [mailto:mlennert at club.worldonline.be]
> *Inviato:* ven 08/02/2008 11.12
> *A:* marco.pasetti at alice.it
> *Cc:* grass-dev at lists.osgeo.org
> *Oggetto:* Re: [GRASS-dev] GEOS, PostgreSQL and SQLite: needed in GDAL?
> On 08/02/08 10:42, marco.pasetti at alice.it wrote:
> > Hi,
> > sorry to post this again, but it seems to be some contradictions within
> > tutorials and the latest list suggestions; I read from Compile and
> > Install GRASS Wiki:
> > if you want to have DBMS support *in GDAL (subsequently in GRASS)* you
> > have to perform the "Optional" steps below as well.
> > 1) Optional: GEOS
> > 2) Optional: PostgreSQL, mySQL, unixODBC, SQLite (SQLite is needed
> for QGIS)
> > ...while, talking with Moritz, he said me:
> > PostgreSQL and SQLite support in GRASS are independent of such support
> > in GDAL.
> > What should I do? do I need GEOS in GRASS (required by QGIS) and so in
> > GDAL too?
> The support for PostgreSQL and SQLite in GDAL/OGR is about being able to
> access data (spatial or not - see e.g. db.in.ogr) via the GDAL/OGR
> library interface. If you do not compile GDAL with these enabled, this
> will just mean that you cannot use v.in.ogr/r.in.gdal/db.in.ogr, etc to
> access these formats. But that does not keep you from using GRASS.
> The support for PostgreSQL and SQLite in GRASS is about being able to
> handle data attributes (of vector maps) with these systems as backends.
> This concerns modules such as db.connect/v.db.connect, db.select,
> db.execute, etc. Again, you can use GRASS without these backends (i.e.
> with the default dbf driver).
> Compiling GDAL with these formats enabled, does not help you in using
> them as GRASS data attribute backends and in the db.* or v.db.* modules,
> and inversely compiling GRASS with these backend drivers enabled, does
> not change anything concerning the possibilities of importing or
> exporting these formats via v.in.ogr/v.out.ogr or r.in.gdal/r.out.gdal.
> Moritz
