R: [GRASS-dev] Can I trust libtool?
Marco Pasetti
marco.pasetti at alice.it
Mon Feb 11 14:03:25 EST 2008
Good news
Thanks ;-)
MP
-----Messaggio originale-----
Da: grass-dev-bounces at lists.osgeo.org
[mailto:grass-dev-bounces at lists.osgeo.org] Per conto di Ivan Shmakov
Inviato: lunedì 11 febbraio 2008 19.14
A: grass-dev at lists.osgeo.org
Cc: Ivan Shmakov
Oggetto: Re: [GRASS-dev] Can I trust libtool?
>>>>> <marco.pasetti at alice.it> writes:
> Hi, I started to build on Windows (MSYS/MinGW) latest releases of >
GRASS required libraries (zlib, libpng, and so on...) and I thought >
everything was going well... but (occasionally) browsing /usr/lib > dir I
found NO dlls of what I built, only .a and .la libraries, > while I found
dlls in /usr/bin...
I'm not familiar with W32, but IIRC, the dynamic libraries are
searched in PATH on W32. Since /usr/bin is much more likely to
be in PATH than /usr/lib, I deem this behaviour as correct.
There're bugs in any software, and libtool is hardly an
exception, but after using it for quite some time, I'd say that
it's reliable enough.
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
