[GRASS-dev] Re: missing PROJ files
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Feb 12 04:28:01 EST 2008
On Mon, 11 Feb 2008, Michael Barton wrote:
> We've just had some instances where people made new location from
> georeferenced file or from running r.in.gdal and the PROJ_INFO and PROJ_UNIT
> files weren't made--although the location was created with no problems. I
> just tried this with an SRTM geotif and PROJ_INFO and PROJ_UNIT files *WERE*
> made.
Find out what was wrong with the file by runing g.proj -p georef=filename
on it. Probably it is not actually georeferenced or there is some problem
with GDAL/OGR reading the georeferencing information.
Paul
