[GRASS-dev] Re: g.gui
Hamish
hamish_b at yahoo.com
Tue Feb 12 00:44:56 EST 2008
Martin Landa wrote:
> 4. write g.gui module (draft)
> g.gui now in trunk (not compiled by default)
I made a few changes; e.g. added a flag to skip resetting the default.
It's a good start.
some comments:
I am not sure of what the logic is supposed to be if the current
GRASS_GUI setting was "text" or unset? Why bother with that at all?
The type= answer has to be one of the GUIs.
Note that strcmp() returns 0 if the strings are the same.
Also that calls G_store() before G_parser(), and G_store() calls
G_malloc() which can call G_fatal_error(), which must not be called
before G_parser() has been called.
is type= the best word to use as the option name?
gui=? start=? (like d.mon) launch=? ???= ?
Can the wxgui startup take a saved project file as a command line
option like d.m and gis.m? (dmrc=)
If so, once the command-line is built, use G_spawn() instead of
G_system()?
Even though d.m and gis.m fork themselves off, 'g.gui --ui' sticks in
"Run" mode until it finishes. (I don't know if that's harmless or not,
and if fork() would change that)
> > > 5. copy wxgui script to $GISBASE/etc/wxpython (not to
> > > $GISBASE/scripts)
> I think we can do this step too (before 6.3.0/1), just to test now
> g.gui module.
Thinking again about what to name that- as it is a grass program
shouldn't we try for some "g.module" style name? {m|d|g}.wxgui?
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
