#31: NVIZ in GRASS6.2.3 (some problems)
Reporter: clerici | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.2.3
Resolution: | Keywords: nviz
Changes (by marisn):
* keywords: => nviz
Comment:
Replying to [ticket:31 clerici]:
> 1) In the control panel the LOOK cancel button does not work (it works
on 6.0)
Doesn't exist in svn-trunk anymore;
> 2) In the control panel the LOOK RESET button does not reset twist
(bug?)
Fixed by r30082;
> 3) In the Surface panel the masking doesn't have any effect on 'fine'
surfaces but only on 'wire' surfaces and vectors maps.
Can You, please, give a example?
> 4) In the Surface panel the emission parameter (in Surface Attribute)
seems ineffective.
Confirming. I saw no difference in output while changing emission
constant. Can somebody give an example how to test how emission works?
> 5) In the Surface panel the Transparency function has a strange
behaviour with the 'constant' elevation surfaces. When a transparency
value is assigned to the surface and the DRAW button is pressed, the
surface is hidden by the other surfaces. Only by pressing the Draw Current
button in the Surface panel the transparency is effective, but reduces
progressively each time the button is pressed. If the DRAW button is
pressed again the surface return to be hidden. For a check the
elevation.dem and a surface at an elevation of 5,000 m can be used.
Please give an step-by-step instruction how to reproduce this.
> 6) In the panel Vectors Lines/3D Polygons the Display Flat function
seems ineffective.
Confirming. 3D and 2D maps both don't react on "display flat" function.
Ticket URL: <http://trac.osgeo.org/grass/ticket/31#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
