[GRASS-dev] adding lib_arraystats
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Feb 12 13:26:39 EST 2008
On Tuesday 12 February 2008, Dylan Beaudette wrote:
> On Feb 11, 2008 7:30 PM, Hamish <hamish_b at yahoo.com> wrote:
> > Dylan wrote:
> > > However, an hour spent tinkering around with the R shared lib
> > > examples left me mostly frustrated....
> > From the everything looks like a nail dept:
> > Does R offer SWIG bindings into the lib that we could use with python?
> > Hamish
> This project (http://rpy.sourceforge.net/) comes to mind. Not sure if
> it is SWIG based... It looks like straight-up python:
> import Rpy
> I suppose that the only problem then is getting Rpy installed. On a
> debian-like system you can install R and Rpy via aptitude. If you
> build R from source, then I suppose you would have to build / install
> Rpy in a similar manner.
> Before giving up on the C-API to R, I think that there are a couple
> more approaches, which might be simpler.
> 1. call R in batch mode. this would involve the use of temp files,
> passing data and commands back and forth from GRASS to R-- with the
> shell as mediator. This would only require a vanilla install of R.
> 2. build R as a shared lib, and use the "embedded" interface to R
> commands. There are a couple examples in the source tree for this.
I almost forgot the 3rd option:
use the spGRASS6 library in R, and read-in GRASS vector/raster/dbase files
into an R session.
Dylan
> However-- this is starting to get into the realm of feature bloat...
> As neat as it would be to have R routines which could work directly on
> GRASS data structures, it might be overkill considering the possible
> amount of work. I'll keep checking around and post back other ideas.
> On the other hand-- R has so many great plotting / analysis routines,
> it would be a shame to re-implement these in GRASS if they could be
> easily "plugged-into" via some kind of share library / SWIG
> interface.
> Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
