[GRASS-dev] Re: [GRASS GIS] #32: r.what: shouldn't use static buffers for the inputs
GRASS GIS trac at osgeo.org
Tue Feb 12 13:46:21 EST 2008
  Reporter:  1gray    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:
Comment (by glynn):
 Replying to [comment:1 1gray]:
 > Shouldn't therefore {{{r.rast}}} be replaced by a (supposedly simpler)
 Shell script?
 No.
 For a start, v.what.rast only accepts a single raster map. Also, r.what
 shouldn't depend upon the vector and database functionality (most raster
 modules should still work if e.g. you can't GDAL to work).
Ticket URL: <http://trac.osgeo.org/grass/ticket/32#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
