[GRASS-dev] Re: [GRASS-user] V.extrude... confused
Michael Barton
michael.barton at asu.edu
Wed Feb 13 16:06:33 EST 2008
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Feb 13, 2008, at 1:45 PM, Sampson, David wrote:
> Alright,
> I am using the cygwin version of GRASS and much better results... The
> function does not hang and it completes nicely.
> I guess I was expecting to see a 3D object afterwords. I have to
> turn on
> faces to see anything and still I only see lines.
> Do I have to view this in nVIZ?
> I used 30 and 300 for the height values but I still see nothing.
> Does anyone have more experience using the v.extrude?
AFAIK, you need to use NVIZ to see 2.5/3D.
Michael
> -----Original Message-----
> From: grass-user-bounces at lists.osgeo.org
> [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Michael
> Barton
> Sent: Wednesday, February 13, 2008 10:12
> To: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] V.extrude... confused
> On Feb 13, 2008, at 1:20 AM, grass-user-request at lists.osgeo.org wrote:
>>> The green bar does not complete.
> The fact that the green bar does not get completely to the right
> side of
> the output window does not necessarily mean that the program has hung.
> Is there a little 'running person' icon? If so, the process is still
> going; if not, it's done.
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
