[GRASS-dev] FFmpeg include files location
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Feb 13 16:40:06 EST 2008
On Wed, 13 Feb 2008, Glynn Clements wrote:
> The same reasoning applies to MySQL, PostgreSQL etc. Whether to use
> "#include <directory/file.h>" or to use "#include <file.h>" along with
> -I/path/to/directory is a property of
> how the headers are meant to be used,
                   I didn't realise how easy it was to check this (i.e.
looking to see how the headers include "sibling" headers) nor how
important it was. I do now, quite interesting. I would still consider it
an annoyance though.
> not where they happen to be  installed.
> E.g. OpenGL headers are supposed to be included as <GL/gl.h>, X11
> headers as <X11/Xlib.h>, Athena headers as <X11/Xaw/Text.h>, etc;
> anything else (i.e. moving the prefix to the end of a -I switch) is
> incorrect.
> Any -I switches are determined according to the installation path
> *after* you have determined the correct #include directive.
> If a package is designed so that headers are included without any
> prefix directory, yet installs them into a package-specific
> subdirectory, the intention is that the headers will not be found
> without a specific -I switch.
> BTW:
> 	$ pkg-config --cflags libavcodec
> 	-I/usr/include/ffmpeg
> Ditto for libavformat and libavutil.
>> Also, visualization/nviz/src/Makefile includes references to
>> FFMPEGINCPATH, FFMPEGLIBPATH and FFMPEGLIB but as far as I can see none of
>> the C files in that directory use any FFmpeg functions - can it be
>> removed? (I'm going to test it and see if anything goes wrong...)
> In this case, I think that it can be removed, as none of the OGSF
> headers appear to include the FFMPEG headers.
OK, I've done that.
Paul
