[GRASS-dev] Re: [GRASS GIS] #38: configure.in: wxwidgets and
python checks
Glynn Clements
glynn at gclements.plus.com
Fri Feb 15 18:40:15 EST 2008
Martin Landa wrote:
> > Although, personally I wouldn't bother with the --includes and --libs
> > checks. Those flags are already included in the --cflags and --ldflags
> > checks. Having separate variables could lead to confusion; e.g. using
> > $(PYTHON_INCLUDES) instead of $(PYTHON_CFLAGS) might be sufficient on
> > a developer's system but cause problems with a release.
> I renamed PYTHON_CFLAGS to PYTHONCFLAGS, etc. (to follow naming
> rules), also removed PYTHON_LIBS since there is PYTHON_FDLAGS. I am
> not sure about PYTHONINC (PYTHON_INCLUDES), when compiling C++ code
> (vdigit) I should use PYTHONCFLAGS instead of PYTHONINC even if CFLAGS
> defines C-related compiler switches?
I would assume so, as there is no separate --cxxflags switch.
