[GRASS-dev] r.in.ascii strangeness
andrea antonello andrea.antonello at gmail.com
Fri Feb 15 18:43:41 EST 2008
Tried to import your file on a mac into spearfish location.
Have the same problem you report. But r.stats shows that the data are there.
So I tried to do a d.what.rast on the landuse map that shippes with
spearfish, where I do see data and know I should get a number. but
same here. I get novalues even if i click on a color zone.
No idea about what is going on.
Andrea
>  > Michael Barton wrote:
>  >> I've attached a simple text file that I read into GRASS with
>  >> r.in.ascii.
>  >> r.in.ascii  -f input=/Users/cmbarton/Desktop/
>  >> landuse_stats_all_models_orig2.txt output=landuse2 --overwrite
>  >> (I've tried it with -d, -ifd, and no flags)
>  >> It imports fine with no errors. It displays fine.
>  >> r.info shows that it contains data...
>  >>         N:         40    S:          1   Res:
>  >> 0.975                     |
>  >>  |            E:         50    W:          1   Res:
>  >> 0.98                     |
>  >>  |   Range of data:    min = 0.000000  max = 24055.437500
>  > |            N:         40    S:          1   Res:
>  > 0.975                     |
>  > |            E:         50    W:          1   Res:
>  > 0.98                     |
>  > 24055.437500                     |
>  >> YET...
>  >> If I query ANY cell with r.what, I get...
>  >> 23.979253112|12.2468879668||*
>  >> ALL are null. And it won't display in NVIZ--probably because all
>  >> cells
>  >> are null.
>  >> r.mapcalc 'newmap=1.0*landscape2'
>  >> produces an empty map.
>  >> I've run r.nulls with no effects.
>  >> Anyone have an idea what is wrong?
>  > Did you set the region to match the map?
>  Yes.
>  > If I set the region to the map (g.region rast=test), I can't reproduce
>  > the problem.
>  Looks like v.in.ascii imports this file just fine on a Windows system,
>  but doesn't on my Mac. Haven't had a chance to check it under Linux,
>  myself, but your test suggests that it is Mac specific.
>  Michael
>  grass-dev mailing list
>  grass-dev at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-dev
