[GRASS-dev] FW: [GRASS-user] Projection of dataset does not
appear to match thecurrent location!!!
Glynn Clements
glynn at gclements.plus.com
Sun Feb 17 21:02:37 EST 2008
Markus Neteler wrote:
> I have added the comment from Glynn to the manual page of r.in.gdal
> and in modified form to v.in.ogr.
BTW, I overlooked the r.in.gdal location= option when I wrote that
reply. In this particular case, that appears to be more
straightforward than using a separate g.proj -c step.
