[GRASS-dev] v.mkgrid: New `-p' option to suppress areas
Ivan Shmakov
ivan at theory.asu.ru
Tue Feb 19 03:18:58 EST 2008
In order to use `v.what.rast' a vector of points is needed.
Surely one could use `v.type' to turn the centroids into points
after creating the grid, but the following seems to be a cleaner
solution.
vector/v.mkgrid/main.c (main): New `-p' option to generate points
instead of centroids and to skip the creation of areas as well.
Alternatively, there could be an `-a' flag to turn areas off,
and then `-p' would allow to switch between GV_CENTROID and
GV_CENTROID | GV_POINT (or is that supported?), so that
`v.what.rast' would be possible with otherwise ordinary vector
grids.
Suggestions for a documentation update?
BTW, the `v.what.rast' module (along with `v.mkgrid',
`v.random', `v.overlay', `v.edit' and `v.db.select') seems to
allow quite sophisticated queries on the rasters. Perhaps this
should be mentioned on the wiki.
diff --git a/vector/v.mkgrid/main.c b/vector/v.mkgrid/main.c
index 49c0047..500bfc7 100644
--- a/vector/v.mkgrid/main.c
+++ b/vector/v.mkgrid/main.c
@@ -45,6 +45,8 @@ main (int argc, char *argv[])
struct Map_info Map;
struct Option *vectname, *grid, *coord, *box, *angle, *position_opt;
struct Flag *q;
+ struct Flag *points_fl;
+ int points_p;
struct GModule *module;
struct line_pnts *Points;
@@ -107,6 +109,12 @@ main (int argc, char *argv[])
angle->description = _("Angle of rotation (in degrees counter-clockwise)");
angle->answer = "0";
+ points_fl = G_define_flag ();
+ points_fl->key = 'p';
+ points_fl->description = _("Create grid of points"
+ " instead of areas and centroids");
+ points_fl->answer = 0;
/* please, remove before GRASS 7 released */
q = G_define_flag ();
q->key = 'q';
@@ -123,6 +131,7 @@ main (int argc, char *argv[])
"in future. Please use '--quiet' instead."));
+ points_p = points_fl->answer;
/* get the current window */
G_get_window (&window);
@@ -226,7 +235,10 @@ main (int argc, char *argv[])
if (db_grant_on_table (Driver, Fi->table, DB_PRIV_SELECT, DB_GROUP|DB_PUBLIC ) != DB_OK )
G_fatal_error (_("Unable to grant privileges on table <%s>"), Fi->table );
- write_grid (&grid_info, &Map);
+ if (! points_p) {
+ /* create areas */
+ write_grid (&grid_info, &Map);
/* Create a grid of label points at the centres of the grid cells */
G_verbose_message ( _("Creating centroids...") );
@@ -235,6 +247,7 @@ main (int argc, char *argv[])
attCount = 0;
for( i = 0; i < grid_info.num_rows; ++i ) {
for( j = 0; j < grid_info.num_cols; ++j ) {
+ const int point_type = points_p ? GV_POINT : GV_CENTROID;
double x, y;
x = grid_info.origin_x + ( 0.5 + j ) * grid_info.length;
@@ -247,7 +260,7 @@ main (int argc, char *argv[])
Vect_append_point ( Points, x, y, 0.0 );
Vect_cat_set ( Cats, 1, attCount+1 );
- Vect_write_line ( &Map, GV_CENTROID, Points, Cats );
+ Vect_write_line ( &Map, point_type, Points, Cats );
if ( grid_info.num_rows < 27 && grid_info.num_cols < 27 ) {
sprintf ( buf, "insert into %s values ( %d, %d, %d, '%c', '%c' )", Fi->table, attCount+1,
