[GRASS-dev] missing help for r.cats
Ivan Shmakov ivan at theory.asu.ru
Wed Feb 20 09:05:15 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
 >>> The proper command to search for the latter (assuming POSIX `grep'
 >>> [1]) is:
 >>> $ grep -F r.cats *
 >> Right. FWIW my method was 'grep -rI r\.cats *'
 > If you're doing that from the shell, it needs two backslashes:
 > grep -rI r\\.cats *
 > or quotes:
 > grep -rI 'r\.cats' *
 > so that grep actually "sees" a backslash.
 > Or just use "grep -F" or "fgrep" for searching for fixed strings.
	And since one cannot reliably and portably quote a string into a
	regular expression in Shell, one has to use:
$ grep -F -- "$string" ...
	to search for a user-supplied string in a Shell script.
	(The `--' ``option'' prevents `"$string"' from being processed
	as an option even if it begins with `-'; consider, e. g.: `$
	grep -l *' vs. `$ grep -- -l *'.)
