[GRASS-dev] MASK_OVERRIDE
Glynn Clements
glynn at gclements.plus.com
Thu Feb 21 03:47:24 EST 2008
Ivan Shmakov wrote:
> >> Since the code of both the functions I've modified looks painfully
> >> similar, may I ask for a function to return the (qualified?) name of
> >> the (existing?) mask? Which file should I put it in?
> >> (There're some modules which could use this function as well.)
> > I would say find_file.c for a generic version, with type-specific
> > versions in find_cell.c and find_vect.c.
> ? Are there a ``generic'' mask facility?
No; I was thinking mainly in terms of this part:
> > What are the functions to:
> > * for any valid (possibly qualified) reference for an object
> > (raster, vector, etc.) existing in one of the mapsets
> > comprising the mapset search path, return a corresponding
> > qualified object name;
> I don't think such a function exists at present. It would be easy
> enough to add if there was any use for it; it's just a combination of
> G_find_{cell,vector,<etc>} and G_fully_qualified_name().
"Finding" a map (or other "element") in a mapset has both generic
versions (G_find_file()) and type-specific versions (G_find_cell(),
G_find_vector()), so a G_find_* variant which returns the qualified
name would have generic and type-specific versions.
A function solely to return the qualified name of the current mask
should probably go into mask_info.c.
