[GRASS-dev] r.univar: allow multiple rasters to be processed
Ivan Shmakov
ivan at theory.asu.ru
Thu Feb 21 03:38:55 EST 2008
The following change allows multiple rasters to be processed
with `r.univar'.
raster/r.univar2/r.univar_main.c
(assert.h): Include it.
(set_params): Allow multiple values for `param.inputfile'.
(main): Handle an arbitrary number of rasters.
(open_raster): Split some code off `main'.
(univar_stat_with_percentiles): Likewise.
(process_raster): Likewise.
This is unlike doing `r.univar' in a Shell `for' loop, but
rather (for a set of non-overlapping rasters) like doing
`r.patch' and applying `r.univar' to the result.
(Unfortunately, the rasters I have are already large, and
there're just too many of them, so I'd rather have this feature
in `r.univar'.)
The behaviour of `r.univar' on a single raster shouldn't be
affected by the proposed change.
The remaining issues are:
* if the region has CELLS, then the largest possible value for
`null_cells' is CELLS times the number of rasters given; this
is different from `r.patch' + `r.univar';
* the map types of the rasters must match when processing for
the extended (`-e') statistics; this is an obvious limitation;
* G_percent () is counted from zero for each raster.
diff --git a/raster/r.univar2/r.univar_main.c b/raster/r.univar2/r.univar_main.c
index 588138c..26347e8 100644
--- a/raster/r.univar2/r.univar_main.c
+++ b/raster/r.univar2/r.univar_main.c
@@ -14,6 +14,7 @@
* This program is a replacement for the r.univar shell script
+#include <assert.h>
#define MAIN
#include "globals.h"
@@ -25,7 +26,7 @@ void set_params();
void set_params()
- param.inputfile = G_define_standard_option(G_OPT_R_MAP);
+ param.inputfile = G_define_standard_option (G_OPT_R_MAPS);
param.percentile = G_define_option();
param.percentile->key = "percentile";
@@ -48,26 +49,21 @@ void set_params()
return;
+static int open_raster (const char *infile);
+static univar_stat *univar_stat_with_percentiles (int map_type,
+ int size);
+static void process_raster (univar_stat *stats, int fd,
+ const struct Cell_head *region);
/* **** the main functions for r.univar ************************** */
int main(int argc, char *argv[])
- unsigned int i;
- unsigned int row, col; /* counters */
unsigned int rows, cols; /* totals */
+ int rasters;
- int val_i; /* for misc use */
- float val_f; /* for misc use */
- double val_d; /* for misc use */
- int first = TRUE; /* min/max init flag */
- char *infile, *mapset;
- void *raster_row, *ptr;
- RASTER_MAP_TYPE map_type;
struct Cell_head region;
- int fd;
struct GModule *module;
univar_stat *stats;
@@ -85,8 +81,67 @@ int main(int argc, char *argv[])
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ G_get_window(®ion);
+ rows = region.rows;
+ cols = region.cols;
+ /* count the rasters given */
+ const char **p;
+ for (p = (const char **)param.inputfile->answers, rasters = 0;
+ *p;
+ p++, rasters++)
+ /* process them all */
+ size_t cells = rasters * cols * rows;
+ int map_type = param.extended->answer ? -2 : -1;
+ char **p;
+ stats = ((map_type == -1)
+ ? create_univar_stat_struct (-1, cells, 0)
+ : 0);
+ for (p = (const char **)param.inputfile->answers; *p; p++) {
+ int fd = open_raster (*p);
+ if (map_type != -1) {
+ /* NB: map_type must match when doing extended stats */
+ int this_type = G_get_raster_map_type (fd);
+ assert (this_type > -1);
+ if (map_type < -1) {
+ assert (stats == 0);
+ map_type = this_type;
+ stats = univar_stat_with_percentiles (map_type,
+ cells);
+ } else if (this_type != map_type) {
+ G_fatal_error (_("Raster <%s> type mismatch"), *p);
+ process_raster (stats, fd, ®ion);
+ if (!(param.shell_style->answer))
+ G_percent (rows, rows, 2); /* finish it off */
+ /* create the output */
+ print_stats(stats);
+ /* release memory */
+ free_univar_stat_struct(stats);
- infile = param.inputfile->answer;
+ exit(EXIT_SUCCESS);
+static int
+open_raster (const char *infile)
+ char *mapset;
+ int fd;
mapset = G_find_cell2(infile, "");
if (mapset == NULL) {
@@ -97,23 +152,48 @@ int main(int argc, char *argv[])
if (fd < 0)
G_fatal_error(_("Unable to open raster map <%s>"), infile);
- map_type = G_get_raster_map_type(fd);
+ return fd;
- G_get_window(®ion);
- rows = region.rows; /* use G_window_rows(), G_window_cols() here? */
- cols = region.cols;
+univar_stat_with_percentiles (int map_type, int size)
+ univar_stat *stats;
+ int i;
i = 0;
while(param.percentile->answers[i])
i++;
- stats = create_univar_stat_struct(map_type, cols * rows, i);
+ stats = create_univar_stat_struct (map_type, size, i);
for(i = 0; i < stats->n_perc; i++) {
sscanf(param.percentile->answers[i], "%i", &stats->perc[i]);
+ return stats;
+static void
+process_raster (univar_stat *stats, int fd,
+ /* use G_window_rows(), G_window_cols() here? */
+ const int rows = region->rows;
+ const int cols = region->cols;
+ int first = (stats->n < 1);
+ RASTER_MAP_TYPE map_type;
+ unsigned int row;
+ void *raster_row;
+ map_type = G_get_raster_map_type (fd);
raster_row = G_calloc(cols, G_raster_size(map_type));
for (row = 0; row < rows; row++) {
+ void *ptr;
+ unsigned int col;
if (G_get_raster_row(fd, raster_row, row, map_type) < 0)
G_fatal_error(_("Reading row %d"), row);
@@ -128,7 +208,7 @@ int main(int argc, char *argv[])
if (map_type == CELL_TYPE) {
- val_i = *((CELL *) ptr);
+ const int val_i = *((CELL *) ptr);
stats->sum += val_i;
stats->sumsq += (val_i * val_i);
@@ -150,7 +230,7 @@ int main(int argc, char *argv[])
else if (map_type == FCELL_TYPE) {
- val_f = *((FCELL *) ptr);
+ const float val_f = *((FCELL *) ptr);
stats->sum += val_f;
stats->sumsq += (val_f * val_f);
@@ -172,7 +252,7 @@ int main(int argc, char *argv[])
else if (map_type == DCELL_TYPE) {
- val_d = *((DCELL *) ptr);
+ const double val_d = *((DCELL *) ptr);
stats->sum += val_d;
stats->sumsq += val_d * val_d;
@@ -199,14 +279,4 @@ int main(int argc, char *argv[])
G_percent(row, rows, 2);
- if (!(param.shell_style->answer))
- G_percent(row, rows, 2); /* finish it off */
- /* create the output */
- print_stats(stats);
- /* release memory */
- free_univar_stat_struct(stats);
- exit(EXIT_SUCCESS);
