[GRASS-dev] Re: [GRASS-user] V.extrude... confused
Moritz Lennert
mlennert at club.worldonline.be
Thu Feb 21 07:39:17 EST 2008
On 13/02/08 22:31, Markus Neteler wrote:
> On Feb 13, 2008 10:06 PM, Michael Barton <michael.barton at asu.edu> wrote:
>> On Feb 13, 2008, at 1:45 PM, Sampson, David wrote:
>>> I guess I was expecting to see a 3D object afterwords. I have to
>>> turn on faces to see anything and still I only see lines.
>>> Do I have to view this in nVIZ?
> Yes. In the GRASS monitor you only see (naturally) 2D.
>>> I used 30 and 300 for the height values but I still see nothing.
>>> Does anyone have more experience using the v.extrude?
>> AFAIK, you need to use NVIZ to see 2.5/3D.
> Yes. For example:
> http://grass.osgeo.org/screenshots/vector.php
Would it be possible to add the recipes for some of these screenshots,
i.e. the entire chain of commands from v.extrude to the final
3D-Display, either to the screenshots page or for one example to the
v.extrude page ?
Moritz
