[GRASS-dev] [GRASS GIS] #65: Starting up gis.m& hangs (probably on g.region)
GRASS GIS trac at osgeo.org
Fri Feb 22 02:06:32 EST 2008
 Reporter:  pvbgis   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.3.0
Component:  default  |     Version:  6.3.0 RCs
 Keywords:           |
 After getting grass-6.3.0RC5 I am not able to open the GUI (gis.m&)
 anymore. When looking in Windows taskmanager it appears that g.region is
 the culprit. When I close the g.region process in Windows taskmanager the
 GUI opens. However, when trying to display a map, it hangs again, and
 again it seems to be g.region which gives the problem.
 I tried to go back to grass-6.3.0RC4, but although working fine before, it
 gives me the same problem now. Note that I can still open my database and
 view my data layers with the Grass extension in QGIS without problems.
 I am using Windows XP sp2.
 Thanks
 Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/65>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
