[GRASS-dev] Re: [GRASS GIS] #58: v.digit fails to build on Gentoo
GRASS GIS trac at osgeo.org
Sun Feb 24 11:43:27 EST 2008
  Reporter:  marisn    |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  critical  |   Milestone:  6.3.0
 Component:  default   |     Version:  6.3.0 RCs
Resolution:            |    Keywords:  wxGUI, v.digit
Comment (by martinl):
 Replying to [comment:3 kyngchaos]:
 > Same problem here on OSX.  At least on OSX I can directly link in the
 _gdi_.so binary with a full path.  Or you can create the symlink in some
 place you have permissions to write.  BUT, this is still not a good option
 - directly linking binaries to an internal wxpython library just doesn't
 sound right.  Aren't Python binary extensions something that are normally
 loaded by python extension code?
 Right, this solution is unacceptable, for now just a temporal one. I am
 trying to find better solution, to avoid replacing wxPseudoDC by wxDC in
 C++ code since in wxPython code are used methods of PseudoDC (e.g.
 !TranslateId() for moving selected objects) which are not available for
 wxDC. Suggestions/ideas welcomed. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/58#comment:4>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
