[GRASS-dev] r.terraflow Windows patch
Sun Feb 24 12:06:37 EST 2008
Moritz Lennert wrote:
> > Can someone test the attached patch on Windows (MSys)?
> I now get:
> main.cc: In function `void record_args(int, char**)':
> main.cc:327: error: `ctime_r' undeclared (first use this function)
The attached patch should fix that issue.
If there are any remaining errors, please use "make -k", so that you
get all of them.
Index: raster/r.terraflow/main.cc
--- raster/r.terraflow/main.cc	(revision 30318)
+++ raster/r.terraflow/main.cc	(working copy)
@@ -324,8 +324,12 @@
     exit(1);
+#ifdef __MINGW32__
+  strcpy(buf, ctime(&t));
+#else
   ctime_r(&t, buf);
   buf[24] = '\0';
+#endif
   stats->timestamp(buf);
   *stats << "Command Line: " << endl;
