[GRASS-dev] Manpage HTML markup consistency
Glynn Clements
glynn at gclements.plus.com
Mon Feb 25 12:19:39 EST 2008
Hamish wrote:
> > Also, although g.html2man attempts to handle tables, it doesn't seem
> > to work. Please remove <TABLE> <TD> <TH> from the list of allowed
> > tags.
> Tables can be useful.
They might be useful if they worked.
> I would think it better to try and improve
> g.html2man if the current implementation is not working well, rather
> than ban them.
While it would be better if tables worked, the current situation where
they don't work (at all, AFAICT) but get used anyhow is worse than
simply not using them.
Look at the lrs(1) or r.in.xyz(1) manpages; the table portions are
garbage. This is the "man lrs" output corresponding to the table in
lrs.html:
LRS table structure
| AttributeTypeDescription | rsid integer reference segment ID, unique
in the table | lcat integer category of the line in the LRS map | lid
integer route ID (LID) | start_map double precision distance measured
along the line in LRS map from the beginning of the line to the begin-
ning of the segment (absolute milepost distance) | end_map double pre-
cision distance measured along the line in LRS map from the beginning
of the line to the end of the segment (absolute distance of subsequent
milepost) | start_mp double precision milepost number assigned to the
start of the segment | start_off double precision distance from
start_mp to the start of the segment measured along the physical object
| end_mp double precision milepost number assigned to the end of the
segment | end_off double precision distance from end_mp to end of the
segment measured along the physical object | end_type integer1: the
same as specified for from_ ; 2: calculated from map along the line
from previous MP; 3: defined by user
Given that Python has at least two HTML parsers as part of its
standard library, we would probably be better off replacing g.html2man
with a Python script which uses one of them. The ad-hoc regex-based
approach used by g.html2man will inevitably only accept an ill-defined
subset of HTML.
