R: [GRASS-dev] Build winGRASS with Python and wxPython
Michael Barton
michael.barton at asu.edu
Wed Feb 27 11:12:20 EST 2008
On Feb 27, 2008, at 9:09 AM, Martin Landa wrote:
> straightforward on Linux machines (requires wxPseudoDC from wxPython),
> seems to be not possible on Mac (AFAIU). I will try to find better
> solution ASAP.
Martin,
I DID find the wxWidgets code for Mac. It IS installed, just in a
different place. However, there were other problems and Glynn
indicated that make should be handled a different way for
__libgdi.so. (probably I spelled this wrong from memory)
Hope this helps
Michael
