R: [GRASS-dev] Build winGRASS with Python and wxPython
Glynn Clements
glynn at gclements.plus.com
Wed Feb 27 14:14:45 EST 2008
Michael Barton wrote:
> > mhhh... confused! if I don't have wx-config I cannot enable the new
> > wxPython GUI! (configure fails)
> Leave out the --with-wxwigets. This is only used for compiling vdigit.
> Or maybe put in --without-wxwidgets.
> Or you can leave it in and just ignore the error compiling vdigit I
> think.
The vdigit directory is processed using the same rules as for module
directories. If there is an error building that directory, a line will
be added to the error.log file, but the rest of gui/wxpython will be
processed as normal.
