[GRASS-dev] Plan to build Package to use GRASS from R
Rainer M Krug
r.m.krug at gmail.com
Thu Feb 28 03:29:11 EST 2008
On 28/02/2008, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Glynn Clements wrote:
> > Rainer M Krug wrote:
> >> Sorry for crossposting, but I think this can be of interest for GRASS
> and
> >> R
> >> users.
> >> I am planning to write a package to make the use of GRASS from R
> easier.
> >> The
> >> idea is to wrap the system call to execute the GRASS command into an R
> >> command of the same name.
> >> e.g:
> >> r.to.vect <- function(..., intern=TRUE, ignore.stderr=FALSE)
> >> comm <- paste( "r.to.vect ", ..., sep="" )
> >> print(comm)
> >> system( comm, intern=intern, ignore.stderr=ignore.stderr )
> >> My questions are:
> >> 1) Is this a good way of doing it, or is giving a named list to the
> >> function
> >> more usefull?
> > If R provides a way to pass individual arguments (argc/argv), use that
> > instead of contructing a shell command as a string. Otherwise, you are
> > likely to run into problems with shell metacharacters in argument
> > values.
> > (Replying in Nabble because Rainer's posting has been swallowed by
> > threading everywhere else)
> > This is the key sympton, seen recently in a similar interface to SAGA,
> > where the package author carelessly converted all "/" to "\" (it is only
> > on Windows), thus destroying a valid r.mapcalc-like operation.
> > It is made worse by differences between Unixen and Windows in handling
> > stdout and stderr, and by differences between CygWin and MSYS in what
> the
> > GRASS commands are called in system() - MSYS wants an *.exe.
R has a mechanism to detect the OS and, and that could be used to deal with
"/" or "\" issues as well as other differences (one thing I haven't
considered yet as) .
One way of dealing with the different OS concerning stderr and stdout would
be using the command system() in R as it already adresses these issues (as
far as I know) and I managed to write usable wrappers around a few of the
grass commands, including r.mapcalc. But especially r.mapcalc required
manual tweaking...
> >> 2) Is there a way to obtain easily all commands from GRASS and the
> >> parameters possible and required?
> > You can obtain a list of commands by enumerating the $GISBASE/bin and
> > $GISBASE/scripts directories. Nearly all commands support the
> > --interface-description switch, which outputs details of all of the
> > options in XML. There are several other switches which output the same
> > information in different formats; see the g.parser manpage for
> > details.
> > Actually, the interface problem for R is almost exactly the same as for
> > all the other front ends - think of R as a CLI-UI. Using XML in R to set
> > up commands going from R to GRASS might not be impossible, where there
> > would be only one command - do_GRASS(), taking the GRASS command as its
> > required argument, and relying on the GRASS GUI to put up a dialogue. If
> > there were further arguments, then they would be used in the context of
> > the requested command.
That sounds like a good approach and as a starting point - as ultimately I
would like to be able to call e.g. r.in.bin() from R instead of do_GRASS("
r.in.bin", ...). I am using R a lot at the moment to write ecological
simulation models, and to use the commands directly makes the programs much
more readable as emacs highlights the commands. I will look into xml parsers
under R to geth the information out of the grass command.
> > I haven't been following the GUI discussion, so wonder whether the
> > --interface-description output is cached anywhere? If not, do_GRASS()
> > would retrieve that first, and then try to insert given arguments, using
> > platform specific "glue" to move forward. Has the (excellent, by the
> way)
> > progress on GUI provided a way of passing a "bubble" (say in XML) to
> GRASS
> > commands, to avoid having to step around shell metacharacters? The same
> > for error handling? It feels as though g.parser will help a lot.
If the grass commands are created automatically and included into a package
(in addition to the flexible do_GRASS()), this would not be that relevant,
as the creation of the code only happens once (either at coding time of the
package or at compilation time - that would make the system much more
flexible as only GRASS commands / scripts installed be available).
Rainer
> > Roger
> > Glynn Clements <glynn at gclements.plus.com>
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> http://www.nabble.com/Plan-to-build-Package-to-use-GRASS-from-R-tp15712877p15731306.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation Biology (UCT)
Plant Conservation Unit Department of Botany
University of Cape Town
Rondebosch 7701
South Africa
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080228/b53ee0fb/attachment.html
