[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Thu Feb 28 21:24:22 EST 2008
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Comment (by hamish):
(I see the same with 6.2.1's old script version of r.out.gdal)
it works if the values are in the range of 0-255:
#spearfish
r.out.gdal in=fields out=fields.tif type=Byte
qiv fields.tif # qiv is a quick image viewer
but not if all values are out of range:
r.info -r elevation.dem
min=1066
max=1840
r.info -t elevation.dem
datatype=CELL
r.out.gdal in=elevation.dem out=elv.tif type=Byte
gdalinfo -stats elv.tif | grep STATISTIC
STATISTICS_MINIMUM=255
STATISTICS_MAXIMUM=255
STATISTICS_MEAN=255
STATISTICS_STDDEV=0
r.in.gdal in=elv.tif out=elv2
r.info -r elv2
min=255
max=255
we can try with half the raster in range:
r.mapcalc "elev_0 = elevation.dem - 1066"
r.info -r elev_0
min=0
max=774
r.out.gdal in=elev_0 out=elv0.tif type=Byte
gdalinfo -stats elv0.tif | grep STATISTIC
STATISTICS_MINIMUM=0
STATISTICS_MAXIMUM=254
STATISTICS_MEAN=138.68943338231
STATISTICS_STDDEV=56.526296226099
If I load elv0.tif into an image viewer it comes out as all black. But in
Gimp if you use the eyedropper you can see the index number changes, but
the palette is black for all 256 index entries.
gdalinfo confirms palette info was not written to file:
Band 1 Block=1899x4 Type=Byte, ColorInterp=Palette
NoData Value=255
Metadata:
COLOR_TABLE_RULES_COUNT=0
Color Table (RGB with 256 entries)
0: 0,0,0,255
1: 0,0,0,255
2: 0,0,0,255
3: 0,0,0,255
4: 0,0,0,255
255: 0,0,0,255
I do not know how to apply the Gimp's Topographic.gpl color palette to the
image's private "Colormap" index. It must be possible somehow, but I don't
know Gimp well enough..
If you want to store integer values >255 in the Tiff, you will have to use
one of Int16,UInt16,UInt32,Int32[,CInt16,CInt32?].
If you use type=Int32 etc you should preserve the CELL data for use in
other GIS software, even if the saved palette is bogus.
In the above elev_0 case you can see that the 0-774 raster exported as
Byte (8bit) only preserves elevation values in the range of 0-254.
Only Byte and UInt16 will attempt to write out a color palette to the
GeoTIFF AFAIK.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
