[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not work
GRASS GIS trac at osgeo.org
Fri Feb 29 13:48:41 EST 2008
  Reporter:  helena   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:  r.out.gdal, tiff
Comment (by dylan):
 The data range as reported in ArcMap 9.2 when opening a geotiff exported
 from r.out.gdal is (1.17549e-038,3.40282e+038).
 I have noticed that when setting the files symbology, when set to a fixed
 number of classes (ranges) the correct data range is displayed, and the
 image seems to work fine. This suggests that it may be an out of range or
 unusual (in terms of ArcMap logic) no-data value.
 [http://casoilresource.lawr.ucdavis.edu/drupal/node/337 I have updated my
 notes here]
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
